Once you have copied a local boot image to the clipboard, you can register it by right clicking the Boot Images folder and selecting a registration option below the Paste Local Boot Image to Register menu.
If you select the Boot Images folder after copying a local boot image to the clipboard, the Paste menu of the main bar will be enabled. This Paste operation registers the boot image data only!
