The Image Prepare System enables several methods to register a local boot image in the connected domain:
Note: Normally you can only select one boot image to perform the registration.
Exception: You can select multiple boot images if the image names are equal regardless of the extension. For example, you can select osinstal.2 and osinstal.3 to perform the registration.
The image will be registered using the credentials provided during DSM Explorer login. Each method lets you specify the registration options to register a boot image in the domain:
