Select the Remote Control, Active Sessions node to populate the Active Sessions pane with sessions to hosts controlled by the current Remote Control domain manager. You can view details by double-clicking a particular session to access the Session Information dialog.
From the Active Sessions pane an administrator can terminate active sessions between any host and viewer, which subsequently moves the session records into the Previous Sessions pane.
This pane contains the following fields:
Displays pane-specific tips for selecting options or entering information.
Displays the time that the remote control session started.
Displays the computer name of the remote control host.
Displays the computer name of the remote control viewer.
Displays the user name or ID of the session's remote user.
