Previous Topic: Database Table: File CollectionNext Topic: -Database View: Discovered Virtual Application Images
Database Table: Discovered Software
The Discovered Software table, ca_discovered_software, stores the detected software information.
Note: Available categories and options may vary depending on the products and components installed.
This table contains the following columns:
ASSET_SOURCE_UUID
Includes the computer UUID in which the software is detected.
AUTO_REP_VERSION
Includes the automatic increment counter used by the replication engine for comparing the values before and after the update.
COVERED_BY_NF
Indicates whether software installation is covered by a non-finite license. Valid values are as follows: 1 = True and 0 or NULL = False.
CREATION_DATE
Includes the date when the software was detected.
CREATION_USER
Includes the URI of the user who created the detected software entry. In most of the cases, this is equal to ENGINE.
DEF_SOURCE_TYPE_ID
Includes the default source type ID for the source of the record (foreign key to ca_source_type).
DELETE_TIME
Includes the time when the detected software was deleted.
DIS_SOURCE_TYPE_ID
Includes the type ID of the discovery source.
DIS_SW_UUID
Includes the detected software UUID.
EXCLUDE_REGISTRATION
Indicates that the software is under the Common Object Registration API (CORA) maintenance.
INSTALL_PATH
Includes the Installation path of the detected software.
IS_IGNORED_BY_VULN_IMPACT
Indicates that the software must be ignored during the security vulnerability impact/risk assessment of the asset by eVM.
IS_MANAGED_BY_SERVICE
Indicates whether the software was reported by the agent or added by the user. Detected software managed by the inventory agent can be removed or updated by the agent. Similarly, those added by the user can be removed by the user only.
LABEL
Includes the name of the software installation. For example, if SQL Server is found on a computer, this field could contain the instance name of the installation, 'Engfran Ltd Sales'.
LAST_ACCESSED
Includes the last accessed date.
LAST_UPDATE_DATE
Includes the last updated date.
LAST_UPDATE_USER
Includes the user who has last updated the detected software.
LICENSE_BLOCK_ID
Includes the ID of the license block.
LICENSE_ID
Includes the license ID.
LICENSE_INSTANCE
Indicates the incremental order in which software installations are covered by a license.
Note: This column is currently unused.
LICENSE_UUID
Includes the license UUID.
ORIGIN
Identifies the source of the detected software.
PRODUCT_GUID
Includes the vendor installation product identifier.
SERIAL_NUMBER
Includes the attributes of the asset.
SW_DEF_UUID
Includes the software definition UUID.
TRUST_LEVEL
Indicates the trust level of the detected software.
VERSION_NUMBER
Includes the software version detected.
