Previous Topic: Database Table: Discovered SoftwareNext Topic: Database Table: Job Status
-Database View: Discovered Virtual Application Images
The Discovered Software database view, ca_v_discovered_software, displays the same data that is available in the Discovered Software database table plus the following columns specific to virtualized applications:
NAME
Indicates the name of the discovered software.
Software_format
Indicates the format of the discovered software. Valid values are as follows:
0 = Regular application
1 = Virtual application image
2 = Virtualized application.
SOFTWARE_TYPE_ID
Indicates the specific software subtype. Valid values are as follows:
0 = Undefined
1 = Patch
2 = Release
3 = Suite
4 = Configuration Settings
5 = Service
6 = Product
7 = Operating System
8 = Virtual Machine
9 = Patch Roll Up
10 = User Defined Patch
11 = SD Installable Patch
12 = Product Family
13 = Undefined
14 = Undefined
vapp_props
Displays the properties of the discovered virtual application image as reported by the agent.
VIRTUAL_PACKAGE_NAME
Identifies the name of the virtual application image that contains the discovered virtual application, where Software_format= 1. Anything other than 1, the value will be NULL.
VIRTUAL_PACKAGE_UUID
Includes the software definition UUID for the virtual application image, where INSTALLATION_TYPE = 1. Where INSTALLATION_TYPE = 0, this will be NULL.
