Previous Topic: Configure the Delivery LocationNext Topic: Task Status
Scheduling
The CA Asset Converter for Microsoft SCCM task uses the same scheduling dialog as all other engine tasks. As a full extraction of SCCM data may be time consuming and may create load on the SCCM database server, it is recommended that the task be scheduled at a time when the server is most likely to be idle.
