The Delivery Location tab specifies where the XML files produced by the Asset Converter task are to be placed. This would typically be the collection folder of an Asset Collector installation.
Use the following procedure to configure the Delivery Location.
To Configure the Delivery Location
Specifies that the files are written to the collection folder of the Asset Collector running on the same machine as the CA Asset Converter for Microsoft SMS/SCCM task. This is the default setting.
Note: If the machine has no Asset Collector installed, the CA Asset Converter for Microsoft SMS/SCCM task will fail.
Specifies that the files are placed in the specified local or network folder.
