Asset Management › Inventory › Origin and Trust Level of the Hardware Inventory
You can view the origin and trust level of the hardware inventory from the following locations in the DSM Explorer:
- The Information pane of the Inventory folder. You can select any inventory item to see its origin and trust level in the information pane.
- The Origin and Trust Level columns in the right pane of the additional inventory folders. These columns are hidden by default. You can enable them by right-clicking the column header and selecting Origin and Trust Level.
