Previous Topic: User PermissionsNext Topic: User Remote Control Permissions Dialog
Add User Permission Dialog
Use this dialog to define remote control user permissions for a user account or group.
This dialog contains the following fields:
Select a Security Authority and Browse for Principals
Displays the available security authorities. Select an authority from the directories tree and browse for principals.
Security Principal Properties
The following fields specify the security principal properties:
Container Identifier
Displays the container identifier of the item selected in the directories tree.
Names
Lets you use the Add button to select security principals and add them to the Names list. Multiple names should be separated by semicolons.
Description
Identifies the user or group account selected as a security principal.
List of Security Principals
Lists all security principals whose permissions are about to be added to the address book group.
This dialog contains the following buttons:
Add
Adds selected users to the list of security principals.
Remove
Removes a selected security principal from the list.
