The Replayer pane provides information about recorded sessions and open replays. This pane contains the following options:
Displays the Recently Recorded Sessions pane, which contains a listing of the last 10 recorded remote control sessions.
Displays the Recently Replayed Sessions pane, which lets you view the last 10 recently replayed recorded sessions.
Displays the Active Replays pane, which contains a listing of all active replays, that is, recordings that are currently being played back.
If the Tasks portlet is visible, the following tasks are available:
Invokes a standard Open dialog from which you can choose a recorded session. In this dialog, you can navigate the directory structure or enter the name of the recorded session you want to replay.
Displays the Replayer Properties dialog, which lets you configure how the replayer operates.
These tasks are also available by right-clicking the Replayer root node in the DSM Remote Control tree and choosing the appropriate option.
