The configuration mode lets you select the entries that you want to be displayed in the Status portlet, for example:
Clicking the configure icon in the upper-right corner of the Status portlet switches the portlet to configuration mode.
When finished, click the icon again to end the Status configuration mode.
Select or clear the check box next to the List Violated Query Policy and Software Policies fields to include or exclude them from being displayed.
Enter configuration mode by clicking the Configure icon to specify the maximum number of items from each source.
You can select or clear the List Erroneous Asset Jobs, List Erroneous Collect Modules, OS Image Installations, and the Software Jobs fields.
Note: Available categories and options may vary depending on the products and components installed.
You can select or clear the List Prevented Applications field.
Enter the configuration mode by clicking the Configure icon to specify the maximum number of items from each source.
Shows the status of various agents, including Intel AMT, asset management (AM), remote control (RC), software delivery (SD), and Protection agents.
Protection status refers to status information for the different Anti-Virus, Anti-Spyware and HIPS monitored agents.
