Previous Topic: Integrate an Imaging ToolNext Topic: New OS Image
View or Delete the Images Captured with a Support OS Image
You can view the images captured with a support OS image to decide whether to retain them or delete them.
To view or delete the images captured with a support OS image
  1. Navigate to Software, Boot and OS Image Library, Image Prepare System, Local OS Images.
    The local OS images are listed in the right pane.
  2. Right-click the image that is of type GETIMAGE, GETIMAGE-WEPOS, or GETIMAGE-WIN7 and select Properties.
    The Local OS Image Properties dialog appears.
  3. Click the Captured Images tab.
    The page lists all the images captured and the associated model computers for the selected OS image.
  4. (Optional) Select an image or model computer that you no longer require and click Delete.
    Note: Deleting a model computer deletes all the associated images.
    The selected image or model computer is deleted from the image store.
