Before you can capture a model computer using an imaging tool, you must integrate the imaging tool with the OS image. Integrating an imaging tool requires that you add certain files to the OS image.
Note: If Windows AIK is installed on the local Image Prepare System, Microsoft ImageX tool is automatically integrated.
To integrate an imaging tool
The local OS images are listed in the right pane.
The OS Image Properties dialog appears.
The page lists the imaging tools and the integration state.
Select Folder for Imaging Tool dialog appears.
You are returned to the Imaging Tool Integration tab where you can see the following changes:
The imaging tool is integrated with the OS image.
Note: For more information about creating OS images, see the OS Installation Management Administration Guide.
