Previous Topic: Update Boot Image WizardNext Topic: Remote Control
Update OS Image Wizard
The Update OS Image wizard guides you through the process of updating an OS image. The wizard contains all necessary information to complete the task. If you need more details, see the OS Installation Administration Guide.
The basic steps to update an OS image are as follows:
  1. Select the OS image you want to update.
  2. Specify whether you want to update only the local image, or only register the image in the domain, or do both. Depending on your selection, the wizard takes you to different set of pages.
  3. If you have opted to update the local image with additional software, you must provide the path to the source folder of additional software such as device drivers, hotfixes, and language packs.
  4. If you have opted to register the image in the domain, you must select a registration option and then provide the domain authentication details.
  5. Review the settings and click Finish to start the image update.
