Previous Topic: Properties for Task: Text File TabNext Topic: Specify Connection Details for the Database Synchronization Task
The Database Synchronization task synchronizes CA ITCM assets and inventory data that are collected in a Microsoft SQL Server (on Windows) of the DSM domain or enterprise manager with the accordant data in the remote SQL server (on Windows) or Oracle DBMS (on Solaris).
The synchronization is initiated through an engine task that runs at a scheduled time. You create this engine task and define the scheduling for the task using the engine task creation wizard through the DSM Explorer GUI. It is possible to use a separate engine on a remote computer to perform the database synchronization.
To create the Database Synchronization task, navigate to Control Panel, Engines, All Engines, and right-click the engine that should perform the Database Synchronization task. Then, select Add New Task from the context menu and follow the instructions in the wizard.
