The Text File tab lets you load the text file to be passed on to the external utility.
This tab contains the following fields:
Displays the contents of the loaded text file.
Opens the Load file to the Job Editor dialog. Locate the text file and click Open. The content of this file is displayed in the above text area. If you have modified the file, you need to load it again to execute and display the modified text.
