Previous Topic: View the Status Information at Group LevelNext Topic: SCAP Inventory
View the Status Information at System Level
At system level, you can view the overall status of a selected computer, and also the product states of CA Anti-Virus, CA Anti-Spyware, or CA HIPS for that computer. You can find the appropriate status in the Overview area, the Agent Status area, and the Instant Diagnostics tab.
To view information at system level
  1. Navigate to Domain, Computers and Users, All Computers, Computer.
    The Homepage pane appears.
  2. View the overall protection status for the computer in the Agent Status area.
  3. View the status information for CA Anti-Virus, CA Anti-Spyware, or CA HIPS in the Overview area. For example, you can display the information for the following fields:
    Anti-Virus Status
    Displays Anti-Virus status
    Asp Status
    Displays Anti-Spyware status
    HIPS Status
    Displays HIPS status
    Note: The CA Anti-Virus, CA Anti-Spyware, and CA HIPS status must be made visible manually by using the Add to Overview functionality.
  4. Click the Instant Diagnostics tab and see the overall status of the protection agent plug-in.
