Previous Topic: Delete Boot ImageNext Topic: OS Image
OS Images Folder
The OS Images folder displays a list of OS images registered in the domain or detected by a boot server.
OS images not yet registered appear as "detected" images.
OS images are also available as software packages in the Software Package Library.
For each OS image the following information will be displayed:
Name
Specifies the name of the image.
Type
Specifies the type of the image with the "short name" of the operating system,for example, WXPP, W2008.
If the image is not yet registered, it is shown as "detected".
Operating System
Specifies the "long name" of the operating system, for example, Windows XP Professional.
Image Flags
Lists the image flags defined for the image. For more information about Image Flags, see the OS Installation Management Administration Guide.
Note: This field is empty for images that are created with the earlier version of CA ITCM.
Registered/Changed
Specifies the date and time of registration of the image; subsequently, if the image is modified, this field is updated to include the date and time when the image is modified.
Code Page
Specifies the name of the codepage, for example, "1252 - Western European"
Comment
Specifies the comment that appears in the software delivery product.
Default: BsmOsImg imagename
SD Package Name
Specifies the name of SD package.
More information:
OS Image
Image Parameter
Assign OS Image
Deploy an Image
Deploy Software Packages
Delete OS Image
Boot / OS Image Properties Tab
Image Flags Tab
Images Flagged as Not FIPS-Compliant
