An OS image is used to setup the operating system on a target computer. This page displays the boot parameters defined for the image. You can edit the boot parameters when an OS image is assigned to a target computer.
For each parameter the following information is shown:
Speficies the name of the parameter.
Displays the default value, if any.
Displays the parameter type.
Displays a comment about the parameter.
