The General section lets you specify the policy name, policy severity, and the query for the policy.
This section contains the following fields:
Defines the name of the policy.
Indicates the severity of a policy.
Default: Message
Indicates that the policy needs more attention and has a severe impact when violated. An Alarm Policy appears in the Alarm section of the Log Overview.
Indicates that the policy is typical for advanced notification or for a potential problem. A Warning Policy appears in the Warning section of the Log Overview.
Indicates that the policy is for informational purposes only. A Message Policy appears in the Message section of the Log Overview.
Specifies the query on which the policy is based. You can select an appropriate query from the drop-down list.
