You can load the command file (.cmd) to be executed by the job using the following fields:
Defines the contents of the loaded command file (.cmd).
Opens the Load file to the Job Editor dialog. Locate the command file (text file) and click Open. The contents of this file appear in the text area. If you have modified the file, you need to load it again to execute and display the modified text.
Note: Command file jobs are executed as batch files by the command interpreter. These are assumed to be in the "oem" codepage of the agent machine. Hence, any character, for example a Euro sign that does not exist in the oem codepage will be lost during conversion.
