Use the Pre-Job tab to specify the actions to be performed before executing the job.
This tab contains the following fields:
Displays a prompt on the computer before executing a job. This is supported only on Windows.
Defines the message text to be shown on the computer.
Displays the Yes button in the message. You can customize this to match your message.
Default: &YES.
Note: The ampersand (&) should be placed in front of the character you want as the shortcut. The character is underscored (_) and the user can press the Alt key + character key.
Displays the No button in the message box. You can customize this to match your message.
Default: &NO
Enables the default setting in combination with the time specified, when selected.
Forces the execution of the action after the specified number of cancellations. This ensures that the user can cancel an action only a limited number of times.
Forces the execution of the action after a given date.
Specifies any mapped network drive that you want to connect to before executing the job. You can use this feature only for jobs created at the User Account level, as this requires access credentials.
This feature is supported only on Windows.
Note: The Map network drive before job execution functionality is not supported on Windows Vista agents.
Specifies the drive letter to which the share will be mapped.
Specifies the name of the share.
Default: \\SERVER\SHARE
Disconnects the temporary drive connection after executing the job.
