Previous Topic: Add Action: SNMP TrapNext Topic: Create New Folder Dialog
Add Action: AMT Command
You can specify the Intel AMT remote commands that you want to execute on the Intel AMT assets when the policy is violated. These commands let you control the Intel AMT assets.
The Configure Policy Actions dialog for this policy contains the following drop-down and check box:
Command
Lists all the commands and lets you select the command that you want to run on the Intel AMT asset. The available commands are as follows:
Power Down
Shuts down the Intel AMT asset.
Power Up
Starts the Intel AMT asset.
Quarantine Asset
Puts the Intel AMT asset in quarantine.
Release Quarantine
Releases the Intel AMT asset from the port - reverse of quarantine.
Perform action when Asset no longer violates Policy
Evaluates the policy as defined during policy creation.
When you select this check box, the following happens when an asset no longer complies with the policy:
