Use the Package tab to specify the information to be taken from the installed programs database in each operating system.
This tab contains the following fields:
Defines the package name that should be checked in the installed programs database.
Defines the package version. If this field is blank, the agent only validates the package name.
You can get this information from different sources depending on the operating system:
