Use the Systems tab to specify the operating system specific parameters for recognizing the definition.
A regular expression on this dialog refers to either the whole string or the string with special characters like *, %, and so on.
Note: The regular expression must match the entire string.
This tab contains the following fields:
Specifies the operating system name. If you have selected Windows as the OS Group in the Recognition tab, this field is disabled because the OS name for all Windows operating systems is Windows. You can edit this field for UNIX/Linux.
Defines the operating system version.
