Verify Prerequisites
The following prerequisites are required for virtual WOL to work:
Note: The RVI agent cannot collect certain BIOS inventory attributes from Linux virtual machines that are running on Microsoft Hyper-V and XenServer servers, Virtual WOL is not supported on such Linux virtual machines.
Note: Virtual WOL is not supported on guests running on the free version of VMware ESXi as the free version restricts API access to the host.
Enable or Disable Virtual WOL for Computers or Groups
Virtual WOL is enabled by default on all the virtual machines. When a virtualization server hosts numerous VMs, but lacks the resources to run them at the same time, you can disable virtual WOL on its VMs. You can enable it back when you want to power up computers remotely.
The virtual WOL is disabled on the computer. The computer or group is added to the "Do not wake" group.
This action verifies that the virtual WOL is disabled.
View Virtual WOL Status of Computers
You can view the virtual WOL status of a computer to know whether you can power it up using CA ITCM. You can view the status in one of the following nodes in DSM Explorer:
Note: This option is available only for DSM components that can perform a bulk wakeup, such as software delivery and DTS. The Can be powered up option is not applicable for remote control.
View Virtual Machines that are Powered Off
You must know whether a virtual machine is powered on or off before you wake it up. You only want to wake up those that are powered off. To view the power on status of virtual machines on a particular virtualization server, navigate to All Computers, Virtualization server, Inventory, Virtualization, Server Virtual Machines. View the State column on the right pane.
Wake a Virtual Machine Using the CLI
You can wake a virtual machine using the CLI. For example, when you want to wake multiple virtual machines using a batch script. The following command wakes a virtual machine:
caf sendwol [user username password password] vm vGUID guid vsvr url rviagent fqdn
Specifies the credentials of an administrative user on the AM remote agent computer. When you use the same computer credential that you are executing the CLI, you can skip the parameters.
Specifies that virtual WOL must be performed.
Specifies the ID of the virtual machine as known to the host. The ID can be a virtual GUID, system ID, or serial number depending on the platform virtualization server type.
Specifies the URL of the virtual server host of the current virtual machine.
Specifies the FQDN of the AM remote agent that discovered the virtual machine.
Virtual WOL Example
This example performs virtual WOL on a virtual machine:
caf sendwol user root password secret vm vsvr https://virt.acme.com/sdk vguid 123456 rviagent rvi3.acme.com
Note: For more detailed information about CAF commands, type caf <command> /? at the command prompt.
Wake a Virtual Machine Using DSM Explorer
You can wake a virtual machine from the DSM Explorer. Right-click the virtual machines that you want to wake and select the Power up option. This action sends the virtual WOL request for the computer. Connect to the virtual machine to see whether the virtual machine is woken up.
