For an introduction, try the Create Software Package tutorial in the Tutorial Pane of the DSM Explorer.
For an introduction, try the Remove Software tutorial in the Tutorial Pane of the DSM Explorer.
For an introduction, try the Group Software Packages tutorial in the Tutorial Pane of the DSM Explorer.
For an introduction, try the Import MSI Package tutorial in the Tutorial Pane of the DSM Explorer.
