Previous Topic: Enable Auditing for Software Usage Collect TaskNext Topic: Template Inventory Collect Task
Specify Advanced Parameters for Software Usage Collect Task
Use the Advanced tab to specify the warning and prevent messages to be displayed when the licenses are not available.
To specify advanced parameters for software usage collect task
  1. Enter the warning message you want to display in the Warning message field. This is applicable if you have selected Display warning message in the Add Application for Monitoring dialog.
  2. Enter the prevent message you want to display in the Prevent message field. This is applicable if you have selected the Prevent execution message in the Add Application for Monitoring dialog.
  3. Specify the snapshot frequency (seconds) in the Snapshot Frequency field. This is the interval for the Software Usage agent to check for the running applications.
    Note: The snapshot frequency impacts the performance of the agent computer. We recommend that you do not specify a value lesser than the default value. However, you can increase the snapshot frequency.
