Previous Topic: Specify Parameters for Online TrackingNext Topic: Specify Advanced Parameters for Software Usage Collect Task
Enable Auditing for Software Usage Collect Task
Use the Auditing tab to enable the auditing feature.
To enable auditing for software usage collect task
  1. Select Enable Auditing to enable auditing and monitoring actions on the executables and libraries of the selected applications. You can view the audited results in the Auditing window of the computer or group.
  2. After selecting the Enable Auditing option, you can select the following options:
    Audit Executables
    Audits the executables of the selected application.
    Audit DLLs
    Audits the libraries of the selected application.
Note: Enabling auditing has an impact on the performance of the agent.
More information:
Auditing Window
