Previous Topic: Properties for Job: Options TabNext Topic: External Utility Jobs
Properties for Job: Exclude Tab
You can exclude certain files or subfolders in the target directory from being removed or overwritten when the directories are synchronized.
Name
Defines the name of the file or subdirectory that should be excluded. Specify only the file name and not the entire path. The asset management agent searches for the file in the main and subdirectories of the target directory.
Type
Specifies whether the type is a File or Directory.
Update
Updates the file name or type after either has been added to the list. Select the file or directory in the list and modify the details in the Name and/or Type field, and click Update.
Add
Adds the name and type of the file or subdirectory to the list of excluded files.
Remove
Removes the selected file in the list.
