The directory synchronization job synchronizes two directories on a computer. Synchronization involves comparing the source and target directories and ensuring that the contents of the former are identical to the latter.
Defines the directory to be compared against (the image)
Defines the directory to be examined for differences (reflection of the image).
Note: The use of UNC path is supported. Syntax:\\servername\sharename.
