Previous Topic: Secure Configuration File JobNext Topic: Properties for Job: Contents Tab
Properties for Job: File Tab
Use the File tab to select the configuration file to be secured. This tab contains the following field:
Configuration File
Specifies the file you want to secure on the computer. You can select the file by clicking Browse.
