Previous Topic: Image ParameterNext Topic: Assign OS Image
Edit Default Values
Important! Default values cannot be edited, if the image is already assigned to a target computer.
  1. Expand the All Boot and OS Images folder and select the registered OS Image in the left hand tree. In the right hand list all the parameters of the OS Image are displayed.
  2. Select a parameter in the right hand list, e.g. "ProductId".
  3. Right-click the parameter to open the Edit OS Installation Parameter dialog and change the parameter value. Click OK.
You can edit further default values repeating steps 2. and 3.
The OS Image is now ready to use.
Next steps:
