The DSM Explorer › Queries Folder › Edit an SQL Statement
In the Query Designer dialog, you can view and modify the SQL statement of a query after creating it.
To edit an SQL statement
- Create a new query.
- Right-click the query in the Query Designer dialog and select Edit SQL.
The SQL statement for the query appears.
- Edit the SQL statement and click OK.
The modified SQL statement is saved.
More information:
Add Advanced Argument Dialog
