The DSM Explorer › Queries Folder › Query Asset Jobs/Collect Tasks
You can create a query to learn the status of asset jobs and collect tasks.
To create an asset job status query
- Right-click the Queries folder and select New.
The Select Target dialog appears
- Select the target group of the query and click OK
The Query Designer dialog appears.
- Click Jobs, Asset Jobs/Collect Tasks
The Select Field dialog appears.
- Expand Jobs Status and select Current Status
- Select the Job the status of which you want to query and select the status to be queried.
- Click OK.
A New Query is created under the selected target group.
- Right-click the query and click Run Query.
The status of the job appears in the selected target group appears.
