Previous Topic: Computer Properties: Agent TabNext Topic: Computer Properties: User Defined Tab
Computer Properties: Agent Tab (External)
The Agent tab contains agent-related information for external agents when the Asset Collector component is installed.
This tab contains the following fields:
Agent name
Identifies the agent name.
Registered
Identifies the date and time when the agent was registered.
Last run
Identifies the date and time when the agent was last run.
Last IP-address
Identifies the last IP address of the agent. If the agent is configured through DHCP (Dynamic Host Configuration Protocol), each time the DHCP Server is restarted, a new IP address is assigned to all the systems connected to the server. This field displays the last IP address of the agent.
Server host name
Identifies the host name of the scalability server that this agent reports to.
Agent restrictions
Shows the agent restrictions, if any. Valid restrictions are as follows:
Trust level
Identifies the trust level of an asset. Trust level is displayed as a range of 1 to 5 stars, 5 being the most trustworthy
Origin
Identifies the source from which the asset is collected.
Description
Provides a brief computer description.
