Previous Topic: Computer Properties: Computer TabNext Topic: Computer Properties: Agent Tab (External)
The Agent tab contains agent-related information for DSM agents.
This tab contains the following fields:
Agent name
Identifies the agent name.
Registered
Identifies the date and time when the agent was registered.
Last run
Identifies the date and time when the agent was last run.
Last IP-address
Identifies the last IP address of the agent. If the agent is configured through DHCP (Dynamic Host Configuration Protocol), each time the DHCP Server is restarted, a new IP address is assigned to all the systems connected to the server. This field displays the last IP address of the agent.
Server host name
Identifies the host name of the scalability server that this agent reports to.
Agent restrictions
Shows the agent restrictions, if any. Valid restrictions are as follows:
Trust level
Indicates the trust level that is sent to the server by the asset. Valid values are 1–5, with 1 being the least trustworthy and 5 the most trustworthy.
Origin
Indicates the source, or origin, of the asset.
Components
Identifies the various agent plug-ins deployed and running on the computer.
Version
Identifies the version numbers of the various agent plug-ins.
Description
Provides a brief computer description.
