A virtual application image definition should be sealed to prevent unintentional changes to its contents. Only a sealed definition with its associated software signature is displayed under the agent's Discovered node.
To seal a virtual application image definition
A context menu appears.
The virtual application image definition is sealed and marked with the following icon: ![]()
Note: Discard Changes can also be used to seal a virtual application image definition, returning the definition to its original sealed state with no changes.
