The DSM Explorer › Software Folder › Definitions Folder › Virtual Application Images Folder › How to Create a New Virtual Application Image › Unseal a Virtual Application Image Definition
You must unseal a virtual application image definition before you can modify its contents.
To unseal a virtual application image definition
- Right-click a sealed virtual application image definition in the Virtual Application Images pane.
A context menu opens.
- Select Unseal from the context menu, or click Unseal in the Tasks portlet of the Virtual Application Images pane.
The virtual application image definition is unsealed and marked with the following icon:
