Previous Topic: Concurrent Mode and Non-Concurrent ModeNext Topic: Task Manager Processes in Concurrent Mode
Concurrent Mode
In concurrent mode, the Task Manager and Installation Manager create additional manager processes. These two manager components are split into multiple separate processes with each process dedicated to perform a specific set of tasks on the domain manager. Each process works independent of the other process. The tasks are assigned to the appropriate process based on the type of the task a process is supposed to handle. As a result, the Task Manager and Installation Manager can cater to several tasks at the same time when run in concurrent mode.
More information:
Configure the Task Manager and the Installation Manager Concurrency
Installation Manager Processes in Concurrent Mode
