Previous Topic: Optimization of Manager ConcurrencyNext Topic: Concurrent Mode
Concurrent Mode and Non-Concurrent Mode
The concurrency behavior of the Task Manager and Installation Manager is independent of each other. You can run the Task Manager, Installation Manager, or both in concurrent or non-concurrent mode, depending on your requirements. The Task Manager and Installation Manager behave differently in these two modes. However, for optimal performance, you must run both the manager components (Task Manager and Installation Manager) in concurrent mode. Before you configure these two manager components to run in concurrent mode to optimize manager concurrency, make sure you understand how the two manager components behave in both the modes.
You can run the Task Manager and Installation Manager in concurrent or non-concurrent mode only on the domain manager. On the enterprise manager, only non-concurrent mode is available.
Note: After you change the concurrency setting for the Task Manager or Installation Manager, make sure that you restart the appropriate plug-in to reflect the changes.
More information:
Configure the Task Manager and the Installation Manager Concurrency
Concurrent Mode
Non-Concurrent Mode
