This command modifies the attributes of an unsealed local software policy. You can optionally seal the policy with this command.
swPolicy action=modify
name=software_policy_name
[newName=new_name_of_software_template]
[jcPriority=«1…10»]
[{transaction|synchronized|nolinkage}]
[rollback[={y|n}]]
[cascade[={y|n}]]
[{nosetup|setup_jobs|setup&activate_jobs}]
[regenerate[={y|n}]]
[evaluateGroup[={y|n}]]
[evaluationStart=YYYY-MM-DD hh:mm]
[globalTime[={y|n}]]
[evaluationPeriod=hours]
[calendarname=calendar_name]
[{adhoc_disable|adhoc_only|adhoc_always}]
[comment=new_comment_on_the_software_policy]
[seal[={y|n}]]
[userMessage]
The name of a local software policy that is modified.
Specifies the new name of the selected software policy.
If this option is not coded the policy name is not changed.
This option specifies the new priority for job container generated by this policy. A valid priority is one of the values 1, 2, 3, 4, 5, 6, 7, 8, 9, 10. 1 is the highest priority and 10 is the lowest.
If this option is not coded the priority is not changed.
This option specifies the new job linkage for job containers created by the policy.
The job linkage is not changed.
The job linkage is set to batch jobs without transaction.
The job linkage is set to synchronized job execution.
The job linkage is set to no linkage.
If the option “rollback” or “rollback=y” is coded then the job linkage is set to "Enable Transaction". If the option is coded as “rollback=n” then “Enable Transaction” is not set.
If this option is not coded the option is not changed.
The parameter should only coded if the job is already in batch processing mode or switched to it by using parameter "transaction" with this command.
Default: rollback=n.
If the option “cascade” or cascade=y is coded then the SD will resolve the dependencies of cascaded installation request and add the missing installation orders automatically. If the option is coded as “cascade=n” then the dependency is not resolved any longer.
This option drives the results of the policy’s evaluation:
The degree of automation is not changed.
The degree of automation is changed to checking for conformity only.
The degree of automation is changed to setting up jobs for non conformant targets but does not activate them.
The degree of automation is changed to setting up and activating jobs for non conformant targets.
If the option “regenerate” or “regenerate=y” is coded then all jobs that failed earlier and have not been completed successfully yet are rescheduled for execution for achieving conformity. If the option “regenerate=n” is coded then this rescheduling is now skipped.
If the option “evaluateGroup” or “evaluateGroup=y” is coded then in case of a query group associated with the policy this group will be re-evaluated during the policy’s evaluation too. If “evaluationGroup=n” is coded then this re-evaluation of the group will not happen.
This option specifies a new earliest point in time when the evaluation of the policy will start. The value is specified in ISO format “YYYY-MM-DD hh:mm” where YYYY specifies the year, MM the month, DD the current day of month, hh the hour and mm the minute.
If “globalTime” or “globalTime=y” is specified then the time specifications with the policy are based on enterprise time. If “globalTime=n” is coded then the time is domain based.
This option specifies the new period in which the evaluations of the policy takes place. The value is specified in hours. If 0 is specified then the evaluation happens only once at seal.
This option specifies the name of a new calendar used by the SD for scheduling the time driven actions of the policy. If an empty string is entered then a possibly calendar entry is removed and calendars are no longer taken into account.
This option specifies the new type of adhoc evaluation:
The adhoc evaluation type does not change.
No adhoc evaluation is provided any longer.
The adhoc evaluation now starts when inventory reports of new or re-installed targets arrive.
The adhoc evaluation now starts at any inventory report from targets.
This option specifies the new comment on the software policy. If an empty string is coded then the old comment is removed.
If the option is not coded the comment remains unchanged.
If “seal” or “seal=y” is coded then the policy is sealed after the modification has been completed otherwise it remains unsealed for further modifications. The seal is only performed when the modification has been successful and no error has been reported. Warnings do not suppress the seal.
Modifies the custom administrator message while updating the software policy properties.
