This action lists all software policies registered at the domain or enterprise.
The syntax of the action is as follows:
swPolicy action=list
[{detailed |separator=separator_sign}]
If this option is coded then a detailed list is provided, otherwise a short list is presented only.
The separator is a character that is used for separating the different output fields in the lines of the listings. The default separator is “:” (colon).
The short list with default separator has the following format:
List of Software Policies
Short
«policy_1 name»:«policy_1 type»:«linked group»:«lgroup scope»: [un]sealed
«policy_n name»:«policy_n type»:«linked group»:«group scope»: [un]sealed)
The detailed list has the following format:
Detailed
Policy name : «name of policy 1»
..Policy type : {distributed|local}
..State : {disabled|not evaluated|evaluating|not conformant|conformant}
..Priority : «priority of the template»
..Associated group : «group name»
..Group type : {global|local}
..Last evaluated : «yyyy-mm-dd HH:MM»
..Violators : «number of violators»
..Linkage : {batch|transaction|
synchronized|no linkage}
..Cascade install : {yes|no}
..Degree of automation : {conformity check|setup jobs|setup and activate jobs}
..Regeneration of jobs : {yes|no}
..Dynamic group evaluation : {yes|no}
..Activation time : «yyyy-mm-dd HH:MM»
..Enterprise time driven : {yes|no}
..Evaluation period : «evaluation period»
..Evaluation calendar : «calendar name»
..Adhoc evaluation : {disabled|on new inventory only|always}
Policy name : «name of policy 2»
Policy name : «name of policy n»
