This action allows you to create a software group or a procedure group.
swLibrary action=createGroup name=group_name
[superGroup=super_group_name]
[GroupType={SWG|PG}]
[comment=comment]
Specifies the name of the group to be created.
Specifies the name of the super group where the new group will be created as a subgroup. The super group must be a software group. If the parameter is not coded, the group will be created on top level, that is in folder "Software Package Library".
Specifies the type of group to be created. The following values are valid:
Defines the group as a software group. This is the default.
Defines the group as a procedure group.
Comment on the groups.
