Previous Topic: createGroup—Create GroupNext Topic: deleteGroup—Delete Software or Procedure Group
Example
Suppose a software group named "swg_1" should be created and after this, a procedure group named "pg_1," which is a subgroup of the already existing software group "swg_1". The following commands create these groups.
cadsmcmd swlibrary action=createGroup name=swg_1
cadsmcmd swlibrary action=createGroup name=pg_1 groupType=PG superGroup=swg_1
To check the creation the following command will list all the software and procedure groups available:
cadsmcmd swlibrary action=listGroups recursive
CA IT Client Manager r12
ITCM Command Line Version 12.8.0.xxxx
Copyright (c) 2013 CA. All rights reserved.
Trace mode: Off
Connecting to manager "<default manager>" as user "<default user>" ... ok.
Manager: mymanager
Domain: mydomain
Domain type: Domain
Supporting: CO CCNF USD OSIM
List of groups in the software library
Software Groups
..Group name...........................: Catalog
....Comment............................: CA-Software Delivery Reserved Group
....Creation date......................: 2005-04-09 11:26
....Change date........................: 2005-04-09 11:26
..Group name...........................: Software Delivery
....Change date........................: 2005-04-09 11:27
..Group name...........................: swg_1
....Creation date......................: 2005-04-10 08:51
....Change date........................: 2003-04-10 09:11
....Procedure Groups
......Group name.......................: pg_1
........Comment........................:
........Creation date..................: 2005-04-10 09:11
........Change date....................: 2005-04-10 09:11
SDCMD<A000000>: OK
Adding the argument "recursive" is important, otherwise the procedure group "pg_1" as a subgroup will not be listed, but only the top level groups.
Connecting to manager "kkkkk01b" as user "<default user>" ...OK.
Software Groups
....Creation date......................: 2005-4-09 11:26
....Change date........................: 200504-09 11:27
....Change date........................: 2005-04-10 09:11
SDCMD<A000000>: OK
Now assume that a software group "swg_2" should also be created and a software group "swg_2_1" that is a subgroup of swg_2. Furthermore, another procedure group named pg_2 is needed. The following commands will generate these groups and the intended hierarchy:
cadsmcmd swlibrary action=createGroup name=swg_2 groupType=SWG
cadsmcmd swlibrary action=createGroup name=swg_2_1 superGroup=swg_2
cadsmcmd swlibrary action=createGroup name=pg_2 groupType=PG
Now the recursive list of groups shows the following:
Software Groups
..Group name...........................: swg_2
....Creation date......................: 2005-04-10 09:28
....Change date........................: 200504-10 09:28
....Software Groups
......Group name.......................: swg_2_1
........Creation date..................: 2005-04-10 09:28
........Change date....................: 2005-04-10 09:28
Procedure Groups
..Group name...........................: pg_2
....Creation date......................: 2005-04-10 09:29
....Change date........................: 2005-04-10 09:29
SDCMD<A000000>: OK
