In addition to the checklists bundled with this release, the scanner can scan any valid SCAP data stream. The additional SCAP data stream can be a new or an updated FDCC checklist, a custom checklist, or an SCAP data from any source.
CA ITCM can distribute additional SCAP data streams to the target agent computer automatically. Configuring additional SCAP data streams for automatic distribution involves the following tasks:
The checklist files (SCAP data stream) that you want DCS to scan must be available in a specific directory in the domain manager. The DSM engine checks this directory for new or updated checklists when it runs the Default SCAP Checklist Processing Job.
Copy the SCAP data stream to a new directory under the ITCM_installpath\SCAP_Checklists directory in the domain manager.
Note: You must place all the files belonging to an SCAP data stream or checklist in a directory under the SCAP_Checklists directory.
You can export the configuration information from the SCAP Configuration dialog to a .CFG file. You can use this file to import the configuration information into the SCAP Configuration dialog when creating inventory detection modules for the custom or additional SCAP data streams.
To export the SCAP configuration
The Properties for Module Name dialog appears.
The SCAP Configuration dialog appears with the existing configuration.
The Save As dialog appears.
The configuration is exported to a file in the location you specified.
When you are creating inventory detection modules, you can import information from an SCAP configuration file into the SCAP Configuration dialog. Importing the SCAP configuration fills in the configuration details in the respective fields in the SCAP Configuration dialog.
To import an SCAP Configuration
The Select File to Import dialog appears.
The configuration information is imported into the respective fields in the SCAP Configuration dialog.
Following is the content of a sample SCAP Configuration file:
[SCAP] SCAPPath=FDCC-Major-Version-1.2.1.0\ie7 XCCDFFile=fdcc-ie7-xccdf.xml XCCDFID=fdcc-ie-7 CPEDictionary=fdcc-ie7-cpe-dictionary.xml InvComponent=$SCAP$FDCC IE7 CollectXCCDFResultFile=false CollectOVALResultFiles=false OvaldiPath=ovaldi-ca
