CA ITCM automatically creates inventory detection modules for all the FDCC checklists placed under the SCAP_Checklists folder. When you copy a new version of an existing checklist to a new folder under SCAP_Checklists folder, the existing inventory detection module for the checklist is updated with the information from the latest version. In rare circumstances, you may want to use different versions of a checklist for scanning. In this case, you need to manually create inventory detection modules for the versions that are not currently configured for use. For example, if an inventory detection module is configured to scan the highest version always, you can create inventory detection modules for any older checklist version if you want to use the same for scanning.
To create inventory detection modules
The existing detection modules appear in the right pane.
The Create New Inventory Module dialog appears.
[SCAP] SCAPPath=FDCC-Major-Version-1.2.1.0\ie7 XCCDFFile=fdcc-ie7-xccdf.xml XCCDFID=fdcc-ie-7 XCCDFVersion=v1.2.1.0 XCCDFVersionOptions=v1.2.1.0Profileoptions=`v1.2.1.0;Federal Desktop Core Configuration version 1.2.1.0; CPEDictionary=fdcc-ie7-cpe-dictionary.xml CollectXCCDFResultFile=false CollectOVALResultFiles=false OvaldiPath=ovaldi-ca InvComponent=$SCAP$FDCC IE7
Note: For more information about the parameters and their descriptions, see the appendix SCAP Configuration Parameters.
The inventory detection module for the configured checklist is created and appears under the Inventory Detection Modules folder. Configure one or more hardware inventory collect tasks to include the new inventory detection modules.
