The following is an example of the .wlscr file to be used in this example. The file has been named as 5addmod.wlscr. You can change the Title and Description of the file as described below. Additionally, you also need to look at the highlighted fields to see if these fields require any change:
[General]
Title= Additional Module Test
Description=Select this to perform a fast scan of hardware and software on your computer plus user account inventory
[Platforms]
Windows=Yes
Linux=No
Unix=No
Mac=No
[Download_Windows]
Method=webservice
Executable=cmNriAgent.exe
CommandLine=-script .\addmod.ini -origin "CA Elective Inventory (Basic Scan+User module)"
Files=17
File1=cmNriAgent.exe
File2=addmod.ini
File3=cainf.dll
File4=cawinexf.dll
File5=cfUtilities.dll
File6=msvcp71.dll
File7=msvcr71.dll
File8=cfTrace.dll
File9=cfTrace.ini
File10=amappw32.exe
File11=cfbasichwwnt.exe
File12=cfXMLParser.dll
File13=cfOSServices.dll
File14=cfig40wnt.sys
File15=cfigw32.sys
File16=cfigw64.sys
File17=amusersnt.exe
Follow Steps 4-7 (already explained in the above section) to complete the process.
