Previous Topic: Run the New ModuleNext Topic: Create an INI file
Create the Additional Inventory Collection Module
In this example, a user account inventory collection module is created for the NRI agent.
The procedure to create the additional inventory collection module is very similar to the creation of the template inventory collection module.
Important! Before you start, make sure that you have obtained all necessary binaries that are to be used for this inventory module. You also need to find out the execution of the command line of these modules if you run them from the command prompt. You also need to know the parameters to pass, the output files that are generated, and so on.
The steps involved in this process are as follows:
  1. Creation of the INI file
  2. Creation of the .wlscr file
  3. Follow Steps 4-7 as explained in the Create the Template Inventory Collection Module section.
