Run caprovision.exe (caprovision provision hostname adminusername adminpasswd userid userpasswd) before you perform any action on the Intel AMT asset.
To run the caprovision.exe file, enter the following command:
caprovision -c command -h hostname -os hostOSName -u adminUser -p adminPassword [-usern userName] [-userP userPassword] [-certn certificateName] [-certP certificatePassword] [-i]
Defines the operation to be performed of the Intel AMT asset. Supported operations/commands are provision, unprovision, getprovisioneddata, isdeviceprovisioned. Mandatory only if -i option is not used. The provision option enables the device to work with various commands; that is, it sets the user, password, and tag in the AMT device memory. The unprovision option removes the device from the provision state; that is, it removes the user, password, and tag from the device memory. The getprovisioneddata option lists the provision data for the named device. The isdeviceprovisioned option tells you if a named device has been provisioned.
Defines the host name of the Intel AMT asset. Mandatory only if -i option is not used.
Defines the user name for the administrator. Mandatory only if -i option is not used.
Defines the password for the administrator. Mandatory only if -i option is not used.
Defines the name of the operating system on the Intel AMT asset. Mandatory only if -i option is not used.
Defines the name for the new user. User name is randomly generated if this option is not used and -i option is absent.
Defines the password for the new user. Password is randomly generated automatically if this option is not used and -i option is absent.
Defines the interactive mode. It also prompts the user for the parameters which were not provided at the command line.
